STA8100 NMEA Data Flow Filter
chriswu
Currently using the STA8100_MF_DRAW_Binary_Image_v5_9_22 firmware, could you demonstrate commands to specify the received NMEA data streams, such as $GPGSV, or commands to disable all data streams & control the output frequency? It would be great if there is any GitHub initialization code available.
Thank you.
GalaxyQuest
To access STA8100 firmware configuration, please reach out ST Sales and Marketing. The documents specifying the bit fields to set are not intended for mass market.
2 REPLIES 2
Check firmware docs for $PSTM configuration methods, or Teseo Suite for command code templates/output forms.
I'll lock at docs when at a computer.
GalaxyQuest
