STA8100 NMEA Data Flow Filter
chriswu
Currently using the STA8100_MF_DRAW_Binary_Image_v5_9_22 firmware, could you demonstrate commands to specify the received NMEA data streams, such as $GPGSV, or commands to disable all data streams & control the output frequency? It would be great if there is any GitHub initialization code available.
Thank you.
1 REPLY 1
Check firmware docs for $PSTM configuration methods, or Teseo Suite for command code templates/output forms.
I'll lock at docs when at a computer.
