2025-03-06 10:39 AM - last edited on 2025-03-06 12:49 PM by Peter BENSCH
Is it possible to write our own firmware for STA8135GA IC? I want to get the raw measurements from the baseband IC in STA8135GA and implement my own navigation algorithm and load the firmware to the IC. Is this possible?
2025-03-08 5:31 AM
For ICs like Teseo-5 we provide PVT generally (you cannot load your navigation solution) but we provide code and carrier phase measurements. Therefore, if you want to implement an RTK algorithm for precise positioning, this is possible.
If you want to implement RTK engine running on a host MPU, you can check out our LIV4F module. LIV4F module also outputs code and carrier phase as MSM7 messages like Teseo-5
Regarding Teseo-5 navigation algorithm, could you please private message me your project details?
Industry/Education/Research?
Volume?
Location?
Thanks,
George
2025-03-08 5:31 AM
Volume?
Location?
Thanks,
George
2025-03-08 6:53 AM
Thank you for the info. I have sent you a message.
