PPS output from Teseo-LIV3R
hjsteger0
What is the timing specification of the PPS (Pulse Per Second) output from the Teseo-LIV3R in terms of pulse width and/or duty cycle?  I've reviewed the datasheet, UM2523 (ST Teseo III ROM binary image - User manual), and UM2231 (Teseo-LIV3 GNSS Modules - Hardware Manual) but don't see this specified.
3 REPLIES 3
There are parameters and settings you can read out.
For the docs looks to be 1 Hz 50/50 duty, quantization probably +/-16ns
hjsteger0
Hi Tesla DeLorean,
Thanks for the replying to my question.  In which document did you find this information?
Hi Tesla DeLorean,
I'm not sure if you saw my question from last week.  You wrote "For the docs looks to be 1 Hz 50/50 duty, quantization probably +/-16ns" but I can't find the document that specifies this.  Would you please tell me where you found this specification?
Sincerely,
Hal
