2022-10-12 1:16 PM
As the description on datasheet, this IC can be used as host MCU and can be developed GNSS base application running in internal flash. Is there any EVB and SDK to support it please?
2022-10-12 11:42 PM
Hi
SDK support has been discontinued.
The customer application has to run on an external MCU and Teseo3 works only as GNSS.
Francesco
2022-10-12 11:42 PM
Hi
Francesco
2022-10-13 6:25 AM
So sad to hear it, but thank you for your answer.
