GNSS positioning
Ask questions and find answers on Teseo GNSS positioning solutions. Discuss NMEA sentences, SBAS activation, and signal troubleshooting.
Resolved! TESEO-VIC3D as a replacement
We would like to use the TESEO-VIC3D GNSS receiver as a replacement part without modifying the design.Could you please confirm or comment if the following hardware connections are acceptable for this module?Pin #1 (WakeUP): Pulled-up to VCCPin #4 (WH...
Teseo-LIV3F/Teseo-LIV4F
I have been working with both the Teseo-LIV3F and Teseo-LIV4F GNSS Modules. The Liv3 software datasheet contains all of the information I needed to set up that module. The Teseo LIV4 software datasheet is much shorter and seems to be missing some of ...
Resolved! TeseoVI availability status
According to a Blogpost regarding the the TeseoVI series from February 2025, ST has already released the TeseoVI family chipsets ("ST is launching today the TeseoVI [...]").Yet, as of January 2026, neither the chipsets, nor the modules or the Evaluat...
DMeie.2 by Senior II
  • 293 Views
  • 1 replies
  • 1 kudos
TEOSEO VIC3DA can not get message PSTMDRCAL
Dear St's engineers,I am encountering an issue with the GNSS TESEO VIC3DA module regarding the inability to enable the PSTMDRCAL message output. I have tried the command $PSTMSETPAR,1228,0x800000,1*4F (as described in the CDB table 228, which is used...
HAO1 by Associate II
  • 431 Views
  • 1 replies
Does STA8135G support Galileo E6 HAS raw data?
Since STA8135G is a triple-frequency GNSS chip, its hardware should have the capability to decode the E6 HAS message. However, I can't find related message from its RTCM output. I have searched the web and was informed that it can be supported by upg...
Donald11 by Associate
  • 263 Views
  • 1 replies
