problem with cube ai
2024-05-04 6:19 AM
"I'm facing a challenge with implementing a model on my STM32 board. While the model works flawlessly on some boards, it encounters issues on others. I've verified the hardware compatibility, software configuration, and resource constraints across all boards, but the problem persists. It seems that the model's behavior varies depending on the board, and I'm struggling to identify the root cause. Any insights or suggestions from the community would be greatly appreciated. Thank you!"
STM32F3 Series
2024-07-17 8:52 AM
It is the same code that runs on the board. We may have some specific optimizations for a specific target but that's it.
The best to verify the compatibility of the board is to run the validation on the target and verify that the "cos" is closed to 1.
