I am trying to run my project using X-CUBE-AI library and its throwing me this error. I am using B-U585I-IOT02A discovery kit. "/STM32CubeIDE_1.10.0/Major Project/Debug/../X-CUBE-AI/App/app_x-cube-ai.c:61: undefined reference to `MX_USART1_UART_Init' "
BFaru.1
fauvarque.daniel
If you look in the project I sent this function is defined in the main.c.
It means that you probably disabled in MX the USART1 that is needed to communicate back with the PC.
Just rectify your main.c and add the the USART/CRC/GPIO init from the ones I sent in the project.
3 REPLIES 3
fauvarque.daniel
Here is a System Performance project for the B-U585I-IOT02A as a reference.
Maybe your network was not understood by X-CUBE-AI that causes code generation issues.
This is the code snippet in app_x-cube-ai.c file which is throwing an error. It says undefined reference to `MX_USART1_UART_Init'. Can you please explain how to solve it?
fauvarque.daniel
