Hardware validation of NN model
  • July 28, 2024
  • 7 replies
  • 2655 views
I am validating a classification model on STM32H745-DISC0 board.
The validation is successful but id does not show any accuracy related parameter.
It shows all the parameters except accuracy.
rmse
Mae
L2r
mean
std
Ritesh
Best answer by hamitiya
I assume here you are refering to the validation result in X-CUBE-AI interface in STM32CubeMX.
While doing the validation, could you verify if you have something like these rows in the textual output:
Computing the metrics...
 Cross accuracy report #1 (reference vs C-model)
 notes: - the output of the reference model is used as ground truth/reference value
 - 10 samples (5 items per sample)
 acc=100.00%, rmse=0.000000153, mae=0.000000065, l2r=0.000000396, nse=1.000, cos=1.000
 5 classes (10 samples)
 C0 0 . . . .
 C1 . 0 . . .
 C2 . . 0 . .
 C3 . . . 8 .
 C4 . . . . 2
 Evaluation report (summary)
 Output acc rmse mae l2r mean std nse cos tensor
 X-cross #1 100.00% 0.0000002 0.0000001 0.0000004 -0.0000000 0.0000002 1.0000000 1.0000000 activation_3, (5,), m_id=[5]
 acc : Classification accuracy (all classes)
 rmse : Root Mean Squared Error
 mae : Mean Absolute Error
 l2r : L2 relative error
 nse : Nash-Sutcliffe efficiency criteria, bigger is better, best=1, range=(-inf, 1]
 cos : COsine Similarity, bigger is better, best=1, range=(0, 1]
You should have at least one row (X-cross #<n> where n is the output index).
Best regards,
Yanis
hamitiya
The tool shows accuracy (acc column) means "Classification accuracy". If it is not displayed, it means we were not able to detect your model as a classifier. You can still force this flag with '--classifier' or through the "Advanced Settings" in STM32CubeMX / X-CUBE-AI.
From the embedded documentation:
Classification accuracy (acc)
For classifier model type, Classification accuracy is what we usually mean, when the term accuracy is used. ACC is the ratio between of correct predictions to the total number of inputs. This indicator evaluates the performance of the classifier model, if a regressor type is passed, the ACC is NOT calculated and n.a. value is reported
Best regards,
Yanis
​In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
Ritesh1Author
Thanks for the reply.
I forced the model as classifier,  but still it does not show the accuracy.
Ritesh
hamitiya
hamitiyaBest answer
 C0 0 . . . .
 C1 . 0 . . .
 C2 . . 0 . .
 C3 . . . 8 .
 C4 . . . . 2
Best regards,
Yanis
Ritesh1Author
How to provide images as a validation input.
