B-L4S5I-IOT01A Board, NanoEdge AI Studio : NanoEdge AI model not compile with board project.
‎2024-05-17 05:28 AM - edited ‎2024-05-17 05:30 AM
To STM,
Subject: NanoEdge AI package not compile with B-L4S5I-IOT01A Board.
Board - B-L4S5I-IOT01A Board
AI application tool - NanoEdge AI Studio
CUBEMX
IDE - STM32CubeIDE 1.15.1
1. AI model generate from NanoEdge AI Studio for B-L4S5I-IOT01A Board. Package download for deployment.
2. CUBE mx generate code for B-L4S5I-IOT01A Board.
3. NanoEdge AI Studio package include in code.
4. Code compile for variable from header file of NanoEdge AI.
Please see image file - ModelPackInclude2Code
5. Compilation fail on function call of NanoEdge AI.
Please see image file - Cmplitn fail on edge ai fun cal
Please help to include deployment package to B-L4S5I-IOT01A Board code.
Reference :
[1] https://www.youtube.com/watch?v=yXMUv_C5FGk&t=101s
[2] https://stm32ai.st.com/nanoedge-ai/
[3] https://wiki.stmicroelectronics.cn/stm32mcu/wiki/STM32StepByStep:Step4_Sensors_usage#Using_sensors_with_B-L475E-IOT0-
NanoEdge AI Studio
‎2024-05-20 01:22 AM
You need to include the library path in the project settings:
- Right click on your project > Properties
- Then Click on C/C++ build > Settings
- Then MCU GCC Linker > Libraries
- In Libraries (-l) click on the green + icon and type the name of the library without lib (by default the library name is libneai, so type neai)
- Below in the Library search path (-L), add your path to the library
- Click Apply and Close
Best regards,
Julian
‎2024-05-17 05:53 AM
What error do you get exactly? In your screenshot you commented the code and there are only warnings.
If you can, please include your project (as a .zip for example).
Best regards,
Julian
‎2024-05-19 09:40 PM
- Compilation fail on function call of NanoEdge AI.
Please see image file - compl fail for ai packg
Program - https://drive.google.com/file/d/16dNmOCJFgMpMOzahzxTpnzNy4Ftat050/view?usp=sharing
Best regards,
Julian
‎2024-05-20 02:21 AM
Thank you.
