Nov 28, 2024 7:16 AM UTC
B-CAMS-OMV Camera Module
Is my camera module working fine (all 3 LEDs light up)? I am working with the model zoo image classification project, and facing issue.I have
Julian E.
Nov 28, 2024 8:35 AM UTC
Hello @Hoodand ,
Can you unplug/plug your camera again to see if it helps?
If not, look at the accepted answer in this thread: Solved: STM Model Zoo - STMicroelectronics Community:
  1. Download the .zip file with the .elf inside
  2. Follow the step explained about the elf and STM32CubeProgramer
You will see in the second attachment of the post author that he had a similar issue
If it doesn't work, it probably means that a part of the setup does not work like him. Do you have another DISCO board and Camera?
Have a good day,
Julian
​In order to give better visibility on the answered topics, please click on 'Accept as Solution' on the reply which solved your issue or answered your question.
HoodandAuthor
Nov 29, 2024 8:16 AM UTC
Hello,@
 Julian E,Thank you for your reply. But there is still this situation.Maybe the hardware is broken.It suddenly became like this overnight I don't have extra hardware and can't try again immediately.
Have a good day.
Hoodand.
Julian E.
Nov 29, 2024 4:00 PM UTC
I don't know how fragile these boards are, but mine died recently too...
In any case, if even with the elf it doesn't work, it probably means that it comes from the hardware sadly
Julian
