2019-06-17 7:35 PM
The program has been in irqSysHalt at the time of clock initialization, the clock initialization failed, but I don't know why? Has anyone encountered a similar problem?
Program clock init fail:
The figure below is the clock configuration:
2019-06-27 7:20 PM
Hi, Erwan
Thank you for your reply.
The problem has been solved.
Best regards
zeke
2019-06-27 7:39 AM
Hello ,
Sorry , i do not see any screenshot.
your PC (program counter) should show irqSysHalt
with the debugger you can check LR (Link register)
check the clocktree in SPC5Studio.
Best regards
Erwan
2019-06-27 7:20 PM
Hi, Erwan
Best regards
zeke
2021-07-26 2:33 AM
Hi Zeke,
I have the same problem of irqSysHalt while clock initialization.
Could you please explain how did you solve the problem.
Thanks in advance
Dipak
