2024-08-13 10:19 PM
Hi
I am using UDE STK 2021 debugger software and for that I am using PLS-UDESTK debugger(HW), for SPC58NN84E7 microcontroller I could see the PLS-UDESTK is mentioned as NRND(Not recommended for new design) So I am planning to use AEK-MCU-SPC5LNKU with same above mentioned SW debugger.
Can you any confirm me that AEK-MCU-SPC5LNK supports UDE STK 2021 SW debugger
Thanks in Advance
2024-08-20 05:38 AM
Hello ,
https://www.pls-mc.com/support/downloads/download-spc5-udestk/
SPC5-UDESTK-EVAL version 2021.xx from PLS Side
is the 64 bits version
it should support PLS-UDESTK for SPC56,SPC57 and SPC58
Best Regards
Erwan
2024-08-20 05:38 AM
Hello ,
Best Regards
Erwan
2024-08-20 07:10 AM
Hi Erwan YVIN
Thank you for the information, But since they have mentioned NRND(Not recommended for new design), I am still thinking to weather to by 1year license for SPC5-UDESTK-EVAL debugger. Could you please confirm?
Can you also confirm me that AEK-MCU-SPC5LNK supports UDE STK 2021 SW debugger?
2025-02-12 04:22 AM
Did you ever find out if the AEK-MCU-SPC5LNKU works with UDE STK 2021? I can't find any proper reply online.
It'd seem so, but I need to be sure before making the purchase
