2020-11-21 5:54 AM
hello guys, I want to config SPI to communicate with TJA1145 .the 4 pins are shown in the picture.
but I test the signal by OScilloscope and I found nothing in the four pin which means no meaningful signal. for example the CS pin is always high and no pulse signal in SCK pin.
I list majority signals here , could you pls help me to analysis the config and whether I miss something?
thanks in advance.
2022-05-24 5:17 AM
Sorry for the late answer ,
i recommend you to check the corresponding RM (reference manual) of SPC58NN.
Best Regards
Erwan
2022-05-24 5:17 AM
Best Regards
Erwan
