ST10F280-B3
2023-10-05 9:45 AM - edited 2023-10-05 9:57 AM
Hello!
I have a gearbox actuator on the board, there is a microcontroller ST10F280-B3 VG838478 MYS 22 912, they are not on sale.
Please tell me which microcontroller can be replaced? Are there any analogues?
I myself don’t understand anything about electronics.
I will be very grateful for your help!
Thank you!
2023-10-05 11:14 AM
The VG is a fab code, the 9909T MYS 22 912 are test and packaging codes, dates and location.
Not sure on the 838478, might be a custom program. You'll need to work with the equipment vendor, as OEM parts aren't going to be available on the open market.
https://octopart.com/search?q=ST10F280-B3¤cy=USD&specs=0
2023-10-05 9:59 AM
Hello!
I have a gearbox actuator on the board, there is a microcontroller ST10F280-B3 VG838478 99097 MYS 22 912, they are not on sale.
Thank you!
Probably not, the parts obsolete, and much of the magic might be software inside that you can't extract or duplicate.
2023-10-05 10:30 AM
I was told that I need an empty one, the old one I have cannot be overwritten, on the empty one they could write the program, ST10F280-B3 on the Internet they are available but, not with such numbers as mine, maybe there is a similar analogue
2023-10-05 11:14 AM
2023-10-07 8:04 AM
