2023-08-10 12:37 AM
i used SPC5Studio 5.8.1 for many years, but today (after windows update) in Properties->Tool Chain Editor->Current toolchain->"No ToolChain".
This means that i have no possibility to change Build Settings. The same things also in SPC5Studio 6.
Of course i have C:\SPC5Studio-6.0\eclipse\plugins\com.st.tools.spc5.tools.gnu.gcc.ppcvle.win32_4.9.4.20200908161514\toolchain
Somebody can help to fix this?
Thank you in advantages.
2023-08-25 1:23 AM
Sorry, it does not install by default :
You should install Embedded MCU from Eclipse Marketplace
Cf screenshot
Embedded CDT is nice eclipse feature / plugins to customize your toolchain in SPC5Studio or Eclipse.
Best regards
Erwan
2023-08-16 12:42 AM
Hello ,
we are not using CDT Settings to compile a project.
the toolchain is set in the platform component
if you want to use CDT you set your toolchain in
And set your project as CDT
Best Regards Erwan
2023-08-25 1:06 AM
2023-08-25 1:23 AM
Cf screenshot
Best regards
Erwan
