SPC58NH-DISP board: how to flash it using its USB interface ?
MBour.4
I recently bought SPC58NH-DISP board and I am trying to flash it using its USB interface but now I wonder if that is even possible since in the UDE config it points to JTAG interface and I have no clue on how to modify it if possible.
4 REPLIES 4
LauraCx
*Modified by moderation - please, keep the title shorter than 70 characters*
ODOUV.1
you need an UDE STICK from PLS to be able to program and debug through JTAG
SPC5-UDESTK - USB/JTAG debugger for SPC5 MCUs with software license included (by PLS) - STMicroelectronics
Best regards.
MBour.4
thank you for your response, so the USB interface can not be used for programming ?
Do you have library or API code that can erase / write FLASH?
