2013-07-09 5:15 AM
i have a doubt.
The Daughter/adapter board SPC56ELADPT144S is for SPC56xxEL family.
In SPC56ELADPT144S datasheet is written: device supported SPC56EL60L5.
But when i search in WEB page for SPC56xxEL family i don't find SPC56EL60L5.
WEB page:
http://www.st.com/web/en/catalog/sense_power/FM2098/SC963/SS1534
in MCU list there are SPC56EL60L3 or SPC56EL70L5.
SPC56ELADPT144S support a MCU that it don't exists? i think that's impossible!
There is an error?
However, error apart, are MCU SPC56EL70L5 compatible with SPC56ELADPT144S?
Someone informed?
#spc56el70xx #spc56el70l5Solved! Go to Solution.
2013-07-11 3:13 AM
thanks for your contribute. In addition from ST have confirmed that's ok. MCU SP56EL70L5 is perfectly compatible with SPC56ELADPT144S mini module2013-07-10 12:54 AM
The mini module should be compatible with all the EL devices using that socket. It is possible there is an error on the web site, I tested both SPC56EL60 and SPC56EL70 devices in 144pins package. Giovanni2013-07-11 3:13 AM
