SPC564B70L7 LV Voltage Regulator Problem
orhanyilmaz
Posted on February 01, 2016 at 14:14
How is voltage regulator requirements for SPC564B70L7?(or regulator circuit) I'm trying but not generated 1.2V core voltage.
Thanks.
1 REPLY 1
Erwan YVIN
Posted on February 02, 2016 at 17:02
Hello orhan ,
Maybe you can find the information in the Datasheet
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/CD00272932.pdf
Chapter 3.8.2
       Best Regards
              Erwan
