2016-06-12 12:51 PM
Dear All
I want to rum a timer in my MCU: SPC560D40L1. I am using SPC 5studio. Please advise, if i can generate the code for any specific duration watchdog timer or what documents i should refer to rum a timer. Awaiting for your kind reply. Thanks in advance !! Harsh2016-06-12 11:43 PM
Hi Harsh,
regarding the timer we already discussed about in this topic[DEAD LINK /public/STe2ecommunities/mcu/Lists/SPC56/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/SPC56/SPC560D40L1%20Timer&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000C7B65FFB6DB42540A4DAECE852348058]SPC56D40L1: Timer For Watchdog, you can find related information on RM Chap.30. If you need more help, please let us know which kind of application are you going to implement and we can provide specific example code. Regards, Procolo2016-06-13 4:37 AM
Hi Procolo
I am working on automotive application, in which i am intending to drive LCD display using GPIOs of [DEAD LINK /public/STe2ecommunities/mcu/Lists/SPC56/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/SPC56/SPC560D40L1%20Timer&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000C7B65FFB6DB42540A4DAECE852348058]SPC56D40L1MCU. i asked for related sample code for this in other discussion. LCD's datasheet attached with below mentioned technical specs: Specifications: 1. Operating Temperature: -30 to +85 deg C. 2.Storage temperature: -40 to 95 deg C 3.Operating Voltage: 5V 4. LCD Type: TN Positive 5.Connection type: Pin type 6.Clock viewing: 6'o clock 7. Drive condition: 1/4 DUTY, 1/3 BIAS 8.Display type: Trasflective 9.Polarizer colour: Grey Polarizer: High quality anticlar. Vibration On cluster: freq: 30-500Hz. Please help me in this case. Regards Harsh ________________ Attachments : LCD_display_-_Electronics.jpg : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Htdl&d=%2Fa%2F0X0000000aSB%2FhuQy7WJxs.xZHgjDcOCkYj_8AALxNl3blJRzeAmj.tg&asPdf=false
