Problem With LINFlex when use DFlash
nooshin_1382
Posted on June 26, 2016 at 07:56
Hi Erwan
I Have a problem with LINFlex when i write to DFlash.
in my program before in main loop i do this  :
1)  init the LINFlex.
2) init DFlash
3) erase DFlash and the Write to the DFlash successfully.
4) main loop is started wait for a button goes Low then LIN send a command and recive data
    but when in my program first of program i write to DFlash the LIN recive data but have        no send data when i comment the write to DFlash function all the program is work well.
i don't know is there have relation between a LINFlex and DFlash ??
or this problem is for compiler issue ??
Thanks for help
Best Regards
Nazerian Vanima
1 REPLY 1
Erwan YVIN
Posted on June 27, 2016 at 11:04
Hello Vanima ,
Could you confirm the platform used ?
do you use HAL or RLA ?
Normally there is no relation between between DFLASH and LINFLEX
Could you check if there is no IVOR1 in your code ?
check the ProgramCounter (PC) in ''assembler'' after writing in DFLASH.
I do not think that the problem is a compiler issue.
Best regards
                            Erwan
