Problem With LINFlex when use DFlash
Options
2016-06-25 10:56 PM
Posted on June 26, 2016 at 07:56
Hi Erwan
I Have a problem with LINFlex when i write to DFlash. in my program before in main loop i do this : 1) init the LINFlex. 2) init DFlash 3) erase DFlash and the Write to the DFlash successfully. 4) main loop is started wait for a button goes Low then LIN send a command and recive data but when in my program first of program i write to DFlash the LIN recive data but have no send data when i comment the write to DFlash function all the program is work well. i don't know is there have relation between a LINFlex and DFlash ?? or this problem is for compiler issue ?? Thanks for help Best Regards Nazerian Vanima
1 REPLY 1
Options
2016-06-27 2:04 AM
Posted on June 27, 2016 at 11:04Hello Vanima ,Could you confirm the platform used ?do you use HAL or RLA ?Normally there is no relation between between DFLASH and LINFLEXCould you check if there is no IVOR1 in your code ?check the ProgramCounter (PC) in ''assembler'' after writing in DFLASH.I do not think that the problem is a compiler issue. Best regards Erwan
