Probelm With License File in Spcstudio
nooshin_1382
Posted on June 02, 2015 at 07:59
Hi
one of my partners have problem with his windows when we re install a windows  and then install a spcstudio software when i run spc studio the error showed as in the picture.
i have a license card and email what can i do for this error ?
with Best Regards
Nazerian Vanima
6 REPLIES 6
Erwan YVIN
Posted on June 02, 2015 at 15:24
Hello Vanima ,
the license should be present in :
c:\SPC5Studio\licenses\
could you contact the mail address is
mailto:apgtools-license@st.com
in order to relaunch the lic file
           Best Regards
                     Erwan
nooshin_1382
Posted on June 06, 2015 at 08:24
Hello Erwan
I check Lic File is exist in the same path but stil have problem .
i reinstall the software but stil not work .
i do not know for first time we install the software my partner copy my license form server but when we found , he uninstall the spc and then install the software with his License.
is this issue cause this problem or not ?
thanks
Nazerian Vanima
nooshin_1382
Posted on June 08, 2015 at 07:29
Hi Erwan
I Send email to apgtools but have no response yet .
Best regards
Nazerian Vanima
Erwan YVIN
Posted on June 15, 2015 at 16:40
Hello Vanima ,
Have you received an answer  from ''apgtools'' about your license ?
Best Regards
                          Erwan
nooshin_1382
Posted on June 16, 2015 at 08:07
Hi Erwan
I have not any Response From ''apgtools'' until now and my partner can not work on the project becuase of this issue .
can i install the spcstudio on other computer and use this license or not ?
Thanks so much For your Kind attention Erwan
With Best Regards
Nazerian Vanima
Erwan YVIN
Posted on June 25, 2015 at 14:49
problem solved ;)
Have a nice code ;)
      Best regards
               Erwan
