Licence Problem for SPC56_DRV_LIN2.1-0.9.5 Lin Driver
nooshin_1382
Posted on August 04, 2015 at 17:45
Hi
I Download this software for using Lin Driver on SPCStudio But When you want to setup this software , the software need a serial number but i send request to apg tools
but have no response for my request.
i want to use the LIN Driver how can i use the software?
thanks
Nazerian Vanima
3 REPLIES 3
Erwan YVIN
Posted on August 05, 2015 at 15:57
Hello Vanima ,
I am checking with APG Support team.
Did you use by UART mode ?
because there is some LIN example configuration in serial_lld.c (SPC5Studio source code)
    Best Regards
             Erwan
nooshin_1382
Posted on August 08, 2015 at 11:55
Hello Dear Erwan
Thanks For your response
No I didn`t set for USART, but i did not see any example if there is an example exist for this LIN issue please send it for me.
Can i use a Linflex 0 as uart and use other linflex for LIN BUS ?
Best Regards
Nazerian Vanima
Erwan YVIN
Posted on August 10, 2015 at 17:02
Hello Vanima ,
You can use :
LINFLEX_0 for UART .
and other LINFLEX_x for LIN.
there is a good example for UART in SPC5Studio :
SPC560Bxx OS-Less Test Application for Discovery
in this case, LIN is configured on UART.
  Best Regards
               Erwan
