In SPC56EL60 critical fault LVD/HVD Bist failure is configured in FCCU CFS configuration register to no reset reaction. however when i inject this fault trough fake fault register by writing 21 in them , Reset is happening. could you clarify it?
‎2019-11-10 9:31 PM
according to me it should not lead to reset as in FCCU CFS config register it not configured to perform reset reaction for this critical fault.
‎2019-11-13 7:45 AM
Hello ,
Have you set correctly Register FCCU CF Configuration Register (FCCU_CF_CFG0) CFC21 by 0 ?
For your information ,
have you checked SPC56ELxx_RLA FCCU Test Application for DiscoveryPlus ?
Are you in SAFE mode ?
Best regards
Erwan
‎2019-11-13 7:45 AM
Hello ,
Best regards
Erwan
‎2019-11-13 9:33 PM
Thanks for answer!
The configuration of FCCU is as follow.
FCCU_CF_CFG0 = 0xFFFFFFFFUL
FCCU.CFS_CFG[0] = 0xAAAAAAAAUL //Reset for all Critical fault 0 to 15
FCCU.CFS_CFG[1] = 0xAAAA0000UL // No reset for 16 to 23 critical fault and reset for 24 to 31 critical fault.
also i have check by setting both FCCU.CFS_CFG to 0 , still it is causing reset when 21th critical fault injected through fake fault register.
