i cant find GTM344 details in SPC58NN manual,any one knows where can find that?
szhan.7
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
ODOUV.1
the specification can be found on Bosch GTM web site https://www.bosch-semiconductors.com/ip-modules/gtm-platform/gtm-generic-timer-ip-module/ "GTM IP - Specification V3.1.5.1".
5 REPLIES 5
Peter BENSCH
You will find the description in RM0421, section 45.
If the problem is solved, please mark this thread as answered by selecting Select as best, as also explained here. This will help other users find that answer faster.
Good luck!
/Peter
ODOUV.1
you may find more details in application notes AN5552 AN5693 or AN5695 downloadable on www.st.com
Best regards
ODOUV.1
thanks�?
WAnth.1
This manual is designed to provide the user with an understanding of the RSK hardware functionality, and electrical characteristics. It is intended for users designing sample code on the RSK platform, using the many different incorporated peripheral devices. The manual comprises of an overview of the capabilities of the RSK product, but does not intend to be a guide to embedded programming or hardware design. Further details regarding setting up the RSK and development environment can found in the tutorial manual.
https://knifeplatoon.com0693W00000Une8NQAR.png
