I am using spc58NG DISP and I flashed my code for the first time using UDE4.8 debugger and it worked successfully, then i changed something in my code and wanted to flash it again but i always get this error from the debugger
MAbde.3
Message from component 'PpcJtagTargIntf' :
Can't connect target !
Failed to connect probably because of wrong processor state !
Please check:
- JTAG cable and Target Power
- Target's boot configuration
- Target's PLL configuration
- Censorship password configuration !
Processor is in UNKNOWN state !
Failed to halt processor !
Message from component 'UDEDebugServer' :
Unable to establish connection . To correct the situation, check configuration file entries and try again.
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
0 REPLIES 0
