2021-04-19 11:15 PM
Using SP560B50 MCU, but programming the IC is the complex part.
We used SPC560B54-DIS board to program the B50 IC, but the DIS board repeatedly fails with FDTI driver issue.
Kindly suggest any other programmer or way to program them.
AK
2021-06-03 01:47 AM
Hello ,
maybe you can use JTAG connector.
have you solved your issue ?
Best Regards
Erwan
2021-06-03 01:47 AM
Hello ,
Best Regards
Erwan
