How to program SPC560B50L5 MCU
$AK
Using SP560B50 MCU, but programming the IC is the complex part.
We used SPC560B54-DIS board to program the B50 IC, but the DIS board repeatedly fails with FDTI driver issue.
Kindly suggest any other programmer or way to program them.
AK
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
Erwan YVIN
Hello ,
maybe you can use JTAG connector.
have you solved your issue ?
Best Regards
Erwan
1 REPLY 1
Erwan YVIN
Hello ,
Best Regards
Erwan
