how to enable JTAG in SPC56EL60?
2020-06-24 2:24 AM
Hello there,
I want to enable/disable JTAG in SPC56EL60 microcontroller, however i did not found such information in reference manual.
Could you provide clarify how can JTAG can be enabled/disabled from Sw?
2020-06-25 8:25 AM
Hello ,
You can find some detailed information n the chapter 30 JTAG Controller (JTAGC)
Which board do you use ?
Best Regards
Erwan
2020-06-29 4:00 AM
Hello Erwan,
I gone through chapter 30 JTAG Controller , however i did not find any step to activate deactivate jTAG using Sw.
There are some step mentioned to activate JATG using HARDWARE.
And i am not using any board , but SPC56EL60 used in our project.
So could you please provide some info about how to activate/deactivate JTAG using software ? and it is possible to activate using Sw or not ?
Also by default JTAG in SPC56EL60 will enabled ?
It will be very helpful for me if you provide your response on this.
Thanks in advance
2020-07-02 1:07 AM
Hello DPate ,
Do you use a discovery board , Motherboard + Chip or your own board ?
Best Regards
Erwan
2020-07-02 1:17 AM
Hi Erwan,
As mentioned in previous reply, i am not using any board, but i am using SPC56EL60 in our own board.
Could you please clarify the point i mentioned above?
Also i found only 1 method to activate JTAG , and i think it is not based on Sw. please check attached Snapshot.
