how to add a version information in image?
PLEE.2
hello.
how to put the defined version information(32bit value) in the built image (test.hex or test.bin)?
Javier1
Principal
I use prebuild scripts that includes some github information from the repository.
https://community.st.com/s/question/0D53W00000q6pT7SAI/stm32cubeide-how-to-add-a-custom-pre-post-scripts
You could do something similar with a 32 bit variable
hit me up in https://www.linkedin.com/in/javiermu%C3%B1oz/
4 REPLIES 4
Javier1
Principal
PLEE.2
thanks. javier
It's been a lot of help.
by the way, i use spc5studio..There is no menu that corresponds to the above.
I'm searching hard in my own way.
I want to say thank you again.​
I never used spc5studio, i cannot help you there
Erwan YVIN
Hello PLEE ,
the solution provided by Javier is ok.
you should create your own include file version.
with static const char* VERSION = "myversion"
Best Regards
Erwan
