2023-02-10 7:05 PM
We use WINDRIVER compiler to develop software on ST chip. Can you provide the example mentioned in AN5171 file?
SPC560Dxx_RLA PIT WINDRIVER.zip
2023-02-13 5:09 AM
you are Right, the ZIP was not attached when the PDF was created in 2018.
I will send you by email.
As this example was provided in 2018 and never maintained, it may not compile anymore with new version of WindRiver compiler and with new version of SPC5Studio.
It may need to adapt the Makefiles and other configurations. We will not provide you support on this task.
Best regards.
2023-02-13 5:09 AM
Best regards.
2023-02-13 4:31 PM
hello,
Thank you so much for your help!
