2020-06-23 11:17 AM
microcontroller ST92F150
2020-06-23 12:26 PM
You mean like STVP9 ?
Not sure it can recover protected devices.
2020-06-23 12:31 PM
o que seria STVP9, um programador ou software?
2020-06-23 12:37 PM
Programming software I'd presume
https://community.st.com/s/question/0D50X00009XkhAtSAJ/trying-to-find-st9-visual-programmer-for-epb
This is probably the wrong place for cracking / chipping support
2020-06-23 12:49 PM
e qual hardware devo usar para ler e programar o microcontrolador?
2020-06-23 02:37 PM
A programming method is described in the data sheet as I recall, you could implement that on a platform of your choosing.
Not sure it facilitates a read-back method, you would presumably need a .BIN or .HEX of the firmware you've generated
20 year old stuff, not really much commercial interest at this point. ST used to have an EPROM Programming Board (ST92F120-EPB) you should check with your local sales office. I suspect at this point you'll need to buy or construct your own gear.
http://www.microcontroller-cafe.com.ua/products/automotive/st92f_isp
Programming App Note.
