Device specific model ''SPC563M64L7'' not supported!
Options
‎2014-08-07 3:03 AM
Posted on August 07, 2014 at 12:03
Hello community,
i try to use the PinMap wizard in SPC5 Studio 3 and i receive the meassage ''Device specific model ''SPC563M64L7'' not supported!'' and it seems that there is no support for any model cause i try it with different cpu's. I use the SPC56M- Discovery board and i'm wondering also that this board is not available in the SPC5Studio Application Wizard. Any ideas? Thanks for your help! - MarcSolved! Go to Solution.
Options
‎2014-09-05 6:39 AM
Posted on September 05, 2014 at 15:39
Hello Marc ,
the pinmap SPC563M64L7 is ready and is available by update site.You can install it from the web by using the command ''Install new software'' Best Regards Erwan
4 REPLIES 4
Options
‎2014-08-07 4:34 AM
Posted on August 07, 2014 at 13:34Hello Marc ,SPC5Studio is supported SPC563M64L7 .But, the pinmap wizard for SPC563M64L7 is not ready at the current time.it should be available in the following weeks.(Please check your update site)SPC56M- Discovery board is not available on Application Wizard.Anyway, if you want to be compliant with SPC56M- Discovery, you can update the application SPC563Mxx OS-Less test application. (EVB with SPC563Mxx Mini Module)with good clock settings and update the io settings. Best regards Erwan Yvin
Options
‎2014-08-12 2:25 AM
Posted on August 12, 2014 at 11:25
Thanks a lot for the quick answer!
Options
‎2014-09-05 6:39 AM
Hello Marc ,
the pinmap SPC563M64L7 is ready and is available by update site.You can install it from the web by using the command ''Install new software'' Best Regards ErwanOptions
‎2024-05-24 6:56 PM
Error: flash driver 'spc563mxx' not found
