2021-03-02 10:31 PM
Hello
I am new to SPC5 Studio, please guide me how I can debug my first project.
I am working with SPC5 Studio ver 6.0.0. and have SPC56D_DISCOVERY Eval board.
2021-03-03 02:24 AM
Hello ,
Integrated PLS Debugger (UDE) is a 32 bits product.
it is not compliant anymore with SPC5Studio 6.0.
a change request has been submitted in PLS company
you should use PLS UDE Tools as as external use.
https://community.st.com/s/question/0D53W00000JjNVCSA3/unable-to-install-pls-ude
Best regards
Erwan
2021-03-02 10:49 PM
please, refer to the help integrated within the tool (Help -> Help Contents). There are specific sections dedicated to SPC5Studio.
Luigi
2021-03-02 11:52 PM
Hi
Thanks,
I have gone through the help content and faced following issues:
kindly let me know, where I am wrong.
2021-03-03 12:11 AM
which UDE STK script do you have selected to connect to the target? Could you try to load the script available in the UDE folder (spc560d_discovery_debug_jtag.cfg) within the test application folder?
Luigi
2021-03-03 01:40 AM
Hi
using "Debug.wsx" file in UDE folder of the project.
Thanks for your help, I am able to debug now.
Also, please let me know how to use integrated PLS debugger from the software. Now I am externally using it and opening my configuration file in it.
Following is the attached snip of installing integrated PLS debugger
Thank you
2021-03-03 02:24 AM
Hello ,
Best regards
Erwan
