2019-05-23 06:26 AM
This is for SPC560Bxx. I need clarification on set address for bootloader and the 32-bit address that shall be mentioned on UART/CAN frame.
There is one column in firmware updater component, where we are supported to choose it the set address, here 0x0010000 or 0x0018000, yes, it is mentioned in 28-bits. There shall be another address sent via UART/CAN line, in step 2 of boot process after valid password verification.
I got bit confused here and would like to have a clarification on both its usage.
So,
Thanks for your time on helping me out.
Prashanth
2019-07-17 07:57 AM
Hello ,
have you opened the Document (PDF-PowerPoint) in the document ?
It is very useful to understand the component.
More information are in the RM
Best regards
Erwan
2019-07-17 07:57 AM
Hello ,
Best regards
Erwan
