Compatibility of UDE MemTool with SPC5-UDESTK programmer
Breizh_Instruments
I want to use the automation features of the UDE MemTools with a SPC5-UDESTK programmer, as it is said in this article, but it seams that there is a licence missmatch. Is there a specific license to have in order to use it?
Thank you by advance.
Erwan YVIN
Hello Breish ,
Yes , you can use SPC5-UDESTK programme in CI Automation bench.
https://www.st.com/resource/en/data_brief/spc5-pls.pdf
About license,
the StarterKit version , you are limited to 128k
the registered version unlocks the limitation of code size.
Best Regards
Erwan
Erwan YVIN
Hello Breish ,
About license,
Best Regards
Erwan
Breizh_Instruments
Hello Erwan,
Thank for the answer, but as it is said is the picture, there is no Script support for the SPC5-UDESTK.0693W00000BbNYJQA3.jpg
