Bastien1
Control motor speed (Decrease)
  • June 14, 2021
  • 3 replies
  • 1007 views
I've got an issue.
I'm actually trying to control the speed of the motor with PWM signal.
I'm coding on SPC574S-DISP with SPC5 Studio.
With a Control engineering of the speed I can easily increase the speed, but I can't decrease the speed.
In fact, I can't slow down the motor because of its inertia.
How can I do that?
In advance, thank you for your response.
Respectfully
Bastien
    Javier1
    Principal
    June 14, 2021
    what kind of motor?
    stepper motor? bldc? brushed dc motor?
    In the case of bldc, are you using trapezoidal or foc modulations?
    Maybe show us some code
    hit me up in https://www.linkedin.com/in/javiermuñoz/
    Bastien1
    Bastien1Author
    Thank you for the answer !
    It's a DC motor
    For my code, it's basically a loop for the speed with a PI correction
    Javier1
    Principal
    June 15, 2021
    I dont think we can help you with this little info, try elavorating a bit more:
    showing us the mdel of your motor and maybe some code helps
