2022-08-04 01:28 AM
Hi, i want to ask regarding the sensor library. As i new to SPC5Studio, i want to connect the displacement sensor. So , do i need to declare the sensor library as a header or just simply can use the ADC header library?
2022-08-10 01:05 AM
I do not understad.
Have you an anolog sensor and you want to read the dc value?
In this case see RLA ADC Test Application for Discovery
use button "import samples from application library"
2022-08-10 01:05 AM
I do not understad.
2022-08-10 01:08 AM
ya, i already got it but the problem now is i don't know how to view the ADC output signal on UDE STK. I didnt found the serial monitor on UDE STK . Do you know how can i watch my ADC output signal on UDE STK ?
2022-08-10 03:52 AM
Actually a nerver use, but if you have a evaluation board, see example RLA SERIAL.
Evaluation boards have serial connected to the UDE STK
