2020-12-10 11:15 AM
2020-12-14 02:56 AM
Hi Peter,
The following link: https://www.st.com/resource/en/user_manual/dm00643538-how-to-assemble-and-use-the-autodevkit-adaptive-front-lighting-kits-stmicroelectronics.pdf points to a User-Manual of Adaptive Front Lighting , if you read the chapters 7, 8 you will find all info you need to start with SPC5Studio and AutoEnvKit.
In these Chapters are described step by step all info you need e.g. :
How to create a new project in SPC5-STUDIO
How to add components to an SPC5-STUDIO project
Component configuration in SPC5-STUDIO
How to generate and compile application source code
How to debug an application generated with SPC5-STUDIO.
For what concern the UDE STK tool (Universal Debug Engine) how download it please see chapter 6.
UDE is the tool used to download the compiled file in to the Micro and gives also the possibility to debug at run time.
Alessandro.
2020-12-14 02:56 AM
Hi Peter,
Alessandro.
2020-12-14 06:02 AM
