Kindly find the difference between the LM358DT in the following pictures.
DJain.11
Dear Sir/Madam,
One is from mouser and the other is also from an authorised distributor.
When used, it was found that LM358DT part from mouser was working properly and the part from the other distributor was not working properly. I wanted to know why is there a difference between the working of both the parts. Hope you would help me.
0 REPLIES 0
