2021-09-07 12:00 AM
2021-09-07 12:55 AM
Welcome, @NJami.1, to the community!
It is the TDA7569BLVPD.
Good luck!
/Peter
2021-09-07 01:08 AM
Dear Peter,
Where can I buy this ?
2021-09-07 01:18 AM
This doesn't look like a technical question, but maybe your local distributor can answer this - just refine your search by By Contact Type = Distributors and select your country/region.
/Peter
2021-09-08 02:34 AM
Dear Peter,
This part is not available anywhere, can you help me to locate its availability.
Nusrat
2021-09-08 02:39 AM
@NJami.1 there you go
https://www.digikey.com/en/products/detail/stmicroelectronics/TDA7569BLVPDTR/4755873
2021-09-09 01:05 AM
Dear Peter / Javier,
What is the difference between TDA7569BLVPD & TDA7569BLVPDTR
2021-09-09 01:07 AM
The suffix TR desinotes the Tape'n'Reel option, which usually stands for higher ordering quantities.
/Peter
2021-09-09 01:09 AM
its written in the first page of the datasheet, you should take a look.
https://www.st.com/resource/en/datasheet/tda7569blv.pdf
It seems the difference is in the Packing they come when you buy large quantities.
2021-09-09 04:51 AM
Thank you all for helping me
