I am looking for a part for my Mercedes Audio system, part # 7569B as shown in the attached image
NJami.1
9 REPLIES 9
Peter BENSCH
Welcome, @NJami.1​, to the community!
It is the TDA7569BLVPD.
Good luck!
/Peter
NJami.1
Dear Peter,
Where can I buy this ?
This doesn't look like a technical question, but maybe your local distributor can answer this - just refine your search by By Contact Type = Distributors and select your country/region.
/Peter
NJami.1
Dear Peter,
This part is not available anywhere, can you help me to locate its availability.
Regards,
Nusrat
@NJami.1​ there you go
https://www.digikey.com/en/products/detail/stmicroelectronics/TDA7569BLVPDTR/4755873
Available for consulting/freelancing , hit me up in https://github.com/javiBajoCero
NJami.1
Dear Peter / Javier,
What is the difference between TDA7569BLVPD & TDA7569BLVPDTR
The suffix TR desinotes the Tape'n'Reel option, which usually stands for higher ordering quantities.
/Peter
its written in the first page of the datasheet, you should take a look.
https://www.st.com/resource/en/datasheet/tda7569blv.pdf
It seems the difference is in the Packing they come when you buy large quantities.
NJami.1
Thank you all for helping me
