Evaluation board for TDA7801
erotavlas_turbo
Posted on October 19, 2015 at 18:30
I'm looking for a class AB amplifier with integrated DAC and I2S bus and I found STm TDA7801. I'm a teacher and I would like to use this device at school for some projects. Unfortunately, I have no sufficient ability and time in order to design a board for this integrated circuit. So my question is if there is an evaluation board that I can exploit to use such amplifier. I made a lot of search on the web without finding it. Otherwise, how can I do in order to use it and avoiding to design the board by myself?
Thank you
Salvatore
#tda7801 #dac #i2s #amplifier-ab
1 REPLY 1
Nickname1623_O
Posted on October 26, 2015 at 08:51
hi Salvatore ,
unfortunately TDA7801 demo board was not available in ST website , you may apply an ADC evaluation board , then connected the analog output to TDA7492 evaluation board .
the TDA7492 evaluation board was available from below link.
/st-extranet-web-active/active/en/catalog/tools/PF251979
Thanks ,
YT
