Can i get audio input via 3.5mm jack
‎2024-02-03 7:00 AM
I am using STM3210C-EVAL board. It has a audio jack port. Datasheet says i can play audio but i couldn't find anything about audio input.
My question is:
Can i record audio using a 3.5mm jack microphone via this jack input? And does this jack port support I2S protocol?
If not, what is the best way to get audio input?
Comparators
‎2024-02-03 7:38 AM
Onboard is a DAC -> speaker (headphone) output :
no.
There a BNC -> ADC input connectors:
This is the only way i see , to get a audio signal to the board (+ needs a preamp, you have to build).
Other way to play audio : have audio file on the sd-card and make a program to play via the DAC.
btw
This is a very old (+ expensive!) board and i recommend for any audio use to buy something more up to date ( and cheaper).
‎2024-02-03 7:38 AM
no.
btw
‎2024-02-03 9:57 AM
Thanks for reply,
Just to be sure, i can use i2s MEMS microphone module via pins right? I can configure pins for i2s on CubeIDE.
‎2024-02-03 10:15 AM
Yes, i2s MEMS microphone module via pins on pin header is possible, if you can configure pins for i2s master to free (unused) pins . (I have no circuit of this board, so i cannot see; you have to check, if there are the I2S pins free to use.)
