L6235Q motor stops when applying pwm duty of greater than 90%
shivam1
i am running bldc motor on L6235Q it works properly but when i  increase duty cycle greater than 90% motor get stops so please tell me what is the problem. why my bldc motor is not  running.
Max VIZZINI
We cover automotive-grade products here while the L6235Q is an industrial-grade.
I will move your post in the Analog Community.
On the other side, the information you provide is quite limited for the colleagues to be able to troubleshoot your problem.
If you want to see a complete 3-phase motor driving with automotive-grade products, you can refer to AEK-MOT-3P99081 or AEK-MOT-3P9908M.
https://www.st.com/en/evaluation-tools/aek-mot-3p9908m.html
The source code is F.O.C. source code is available in AutoDevKit www.st.com/autodevkitsw
Best Regards,
AutoDevKit Team
