Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
I2C HAL_error
I have connected a Quad ADC (ADAU1978) to I2C2 peripheral of STM32F407VGT. I ahve also enabled I2S2 peripheral to get audio data from the ADAU1978.I am using HAL API HAL_I2C_IsDeviceReady to check whether the slave is acknowledging or not. This API r...
Problem in the reading of CO value with the board P-Nucleo-IKA02A1
I'm trying to work with P-Nucleo-IKA02A1 but I have some problems: 1) The data of CO that I take from the electronic circuit board with the software UNINUCLEO are not  plausible. The value (made in ppm) is negative and, after a small  physical pressu...
SGuar by Associate
  • 1033 Views
Please Help identify
Im working on an old PPI car audio amplifier. I have a blown transistor but cant find any info about it. Everything i know is that it was made by motorola and S T in top corners P4262 across the middle R125 under that. If possible please provide su...
SWils by Associate
  • 670 Views
  • 0 replies
Vcc+ Vcc- short, Failure reason for TS393 6Z60
I am using TS393 micropower dual CMOS Comparator for last 8-10 years, in my schematic. The PCB is heavily lacquered to protect against moisture damage.Today, in one working board, my team was changing TS393 associated resistor. After the change we n...
