2018-09-14 2:01 AM
2018-09-17 2:10 AM
Yes, whereas this is not explicitely stated in the datasheet, TS912 is unity gain stable.
Howevers, as most op-amps, stability depends on the load at the output. If a large capacitive load (>100pF) is used, stability has to be checked.
Best regards,
Antoine Cros
Op-Amps application team.
