Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
STA326 and/or STA329
A company in China has designed a new amplifier for one of my biggest clients.However, when they sent us samples it is powered by the STA326 chip.As part of my due diligence I realise this chip is marked "obsolete'.When I asked the manufacturer about...
KMill by Senior II
  • 2438 Views
  • 6 replies
BD911 ROHS 2 plan
Please let me know BD911 ROHS2 plan.Or send me ROHS 2 company statement.​
hiwas.12 by Associate II
  • 993 Views
  • 1 replies
Pre-calculation of Geortzel coefficient
Hello, I have found an implementation of the Goertzel algorithm that contains code that I don't understand. And more specifically the pre-calculation of coefficients. :pensive_face: At the top of the code there is :#define DTMF_697Hz 27980 #define DT...
MLamb by Associate
  • 1287 Views
I am using the example project MEMSMIC1 in order to stream audio to host PC. But it is not working beside the following configuration: 2 channels, 16000 sample rate.
When I am changing the number of channels to 1 channel.it is recognized by the windows driver, but the"advanced" TAB is disappear (unlike 2 channels configuration). Did someone faced with this kind problem? Do I missedsomething? of course, audacity d...
AA.10 by Associate III
  • 902 Views
  • 0 replies
