Analog and audio
Find useful information on analog and audio applications: TDA7294-based designs, PDM to PCM noise, and SPICE models.
Forum board changes
Dear community member, The “Analog and audio” topic is no longer supported on the ST community. The legacy content is available only by the read-only basis. If you have any requests regarding "Analog and audio”  topics, check the alternative support ...
TS472
Hi!I'm want to use the component TS472. When I use an input signal -30dBu and a gain 40db it's work fine. When I use an input signalwith 0dBu and a gain 0dB it doesn't word. I don't know why. The outputsignal is less then 1Vpp and not the wave from t...
DSchi.1 by Associate
  • 1482 Views
  • 3 replies
Enable ADC1 in DMA mode on STEVAL-STLKT01
Hi, I am trying to make the ADC1 on the SensorTile Evaluation board work in DMA mode. I have already gotten great help from @berendi​ on the interrupt mode for the ADC. I am still following this tutorial more or less: https://visualgdb.com/tutorials/...
BBecs.1 by Associate II
  • 571 Views
  • 0 replies
Low Layer DMA DAC does not start
Hello,i try for moths to get a wave file from SD to the DAC. I the ST LL_DAC_ADC_project description stands.############################################# LL_DAC_EnableDMAReq(DAC1, LL_DAC_CHANNEL_1); // enable DMA for Channel1 LL_DAC_Enable(DAC1, LL_D...
GIkar by Associate III
  • 1000 Views
  • 1 replies
TSV630 Logic High Level Voltage
Hi,I'm doing a design with TSV630. VCC+ is 3.5 V and VCC- is GND and GAIN=1. What is the minimum Voltage for the SHDN pin to switch the device on? I couldn't find a formular in datasheet. In Datasheed there are only mentioned the different minimum SH...
FHopp.1 by Associate III
  • 905 Views
  • 1 replies
  • 1 kudos
